I am trying to change the dimensions between windows with the 'aligned dimension' but when I click on the dimension it either tries to move the text or asks if I want to change the 'dimension text'
what am I doing wrong?
?? ... select first the window object and then the align dimension will turn in blue showing that now it is editable ..and change it as you want....
