I am trying to see about finding a list of Revit Object properties/attributes. So far I have found a .txt list for the Uniformat Assembly Code for each Revit Object, as well a .txt file of a list of Revit Components.
Does such a file exist?
Thank you for your help!
Patricia
Hello and Welcome to the Discussion!
If I understand you correctly - you are looking for a list of all possible parameters that exist in families?
I do not know of any list. It would be almost impossible to compile such a list. You have a lot of different categories and families in each category. That is not a list I would want to have to make.
Is there something specific you are looking for?
LD
Yes, I am, we are looking for a list of all parameters associated with Revit objects.
If no such list exists, do you have any recommendation as to how we can create/gather one? I realize this will be a complex undertaking but I am willing to try.
You're not going to find a list of all possible parameters for Revit families, since there are an infinite number of parameters. What you probably need is something like the NBIM or ANZRS Revit standards, which describe the format/rules for new parameters.
