Revit 2013 and Citrix
12 REPLIES 12
Message 1 of 13
1364 Views, 12 Replies
Revit 2012 and Citrix Xenapp work great. We upgraded to 2013 and now everything as slowed down so much it is basically not useable. Has anyone else delt with this issue? Is it a by product of Revit 2013, are their some graphic issues present in this release currently not in 2012? Anyone else experiencing this issue?
12 REPLIES 12
Message 2 of 13
john.lipp
Dear jimk
The issue you are describing has been reported to development group and is currently under investigation.
Best regards
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 13
in reply to: john.lipp
Any new info on this issue?
Message 4 of 13
I wish there was. The problem is still a glaring issue with no solution. I am fairly certain there won't be. I am hopeful that 2014 will run better, but we could be faced with the same problem in that release as well. We are looking at trying to accelerate the data with Cisco WAAS as it will work with citrix. Hopefully can get equipment in place in a few weeks and test. 2012 still runs excellent, and we try to keep as many projects in that version as we can.
Message 5 of 13
I'm seeing similar problems.  Was there ever an update on it?
Message 6 of 13
No I never received a solution for this. I am hoping 2014 is better, I see the did some video stuff in that release. What is so disappointing is 2012 works and runs like a champ.
Message 7 of 13
2014 is showing the same behavior as 2013. How could this not be addressed, is there anything we can do? Why say it works on Citrix when you can't hardly run it on Xenapp
Message 8 of 13
Attn: Autodesk Urgent!
This is a serious issue that could have major ramifications to the operations of some companies. 2012 had been working fine on XenApp but 2013 was just far too slow. My understanding from the documents I had read from Autodesk, was that Revit was supported for citrix for 2014 but by the sounds of it, that isn't the case. We are about to test it ourselves but this could have a serious impact on our systems and projects.
Having this fixed for 2014 would be great but we will still have a large number of projects in 2013 that would be affected if/when crossed over to XenApp so a fix for 2013 would also be needed.
Please give us some form of indication whether this will be addressed and addressed soon.
Cheers
Message 9 of 13
This question is for Autodesk: are Revit 2013 and Revit 2014 ready or not ready to perform appropriately as virtualized applications on Citrix Xenapp? Our firm has invested quite some money on a Citrix server farm used mainly for other applications than Revit and we would like to leverage the benefits of this new approach on large BIM projects.
Did any of the other guys get any answer on this matter?
Best wishes for 2014!
Message 10 of 13
We ended up getting a cisco server that supports the Nvidia K2 grid card. All Autodesk apps work excellent on there and are very happy with the results. The key to making it run smooth was the grid card.
Message 11 of 13
mark.wheeler
jimk,
We are working on Citrix XenDesktop implementation on DELL R710 with nvidia K2 but we arent yet satisified with the performance.  I would like to chat with you about your experience.  If you are willing please let me know how we can connect.
Message 12 of 13
HaydnD
Hi JimK
Can you elaborate a bit on your settings for the K2 GRID Cards?
We have Dell R720's and 2 x K2GRIDs per server. The experience in Revit 2013 - 2015 is a bit laggy, especially tool selection and drawing
Message 13 of 13
HaydnD
in reply to: mark.wheeler
Hi Mark
We have much the same setup - did you get to an acceptable experiance?
@mark.wheeler wrote:
jimk,
mark
