Hi There!
I had to uninstall my Revit Building Design Suite premium 2013. I re-installed all the products but on the installation part where i choose which product i want to install, the installation screen tells me that revit is already installed. I have cleaned my registry as instructed on the Autodest website and restarted my computer as well as remove-unistall from control panel. The Autodesk installation screen still sees Revit as already been installed with the green checkmark.
What else is there that i can do? I dont want tell my client that they have to uninstall everything again.
thanks
Dirk
Hi Dirk,
Are you using Windows 7 or older? Try using Microsoft FixIt for installation and uninstallation problem here: http://go.microsoft.com/?linkid=9779673&entrypointid=MATSKB
After you downloaded it, run and choose uninstall problem. You will be able to uninstall Revit.
Then you can try to install it again.
Please note: Don't use it if you use Windows 8
