Revit 2013 Add-Ins Ribbon
4 REPLIES 4
Lineabove
1120 Views, 4 Replies
When you download apps and then add to the ribbon, is there any way to ADD another "Add-Ins" ribbon when number of installed apps exceeds the ribbon's available space ?
Also, some addins create large wide buttons ie: IFC Exporter for Revit 2013 and Revit IFC Export Alternate UI 2013 which have no purpose other than to tell you they are installed. How would you delete these buttons from the Ribbon, as they really have no purpose.
Thanks for any help.
4 REPLIES 4
Intecinfocom
in reply to: Lineabove
it is possible to do throgh additional programming.
a programmer can add more tabs.
Lineabove
in reply to: Intecinfocom
I was hoping that this would be something that could be accomplished through the CUI or even by modifying the *.addin file.  Will wait and see what the 2014 version brings.
Intecinfocom
may be some other users can suggest a better alternate.
souravvignesh
can you sent link for download add in for revit architecture 2013
