Hi why have the levels not showing up on all of the elevations
even when I adjust the drawing viewport??
You may want to check the visibility graphics (VV or VG) to see if they are turned off on the annotation tab in your sections and elevations. Also a quick way is to reveal hidden elements - the lightbulb on the view control bar on the bottom left of your screen.
As for the numbering of the levels - the last level placed in that file before you got to it was level 8 - so level 9 is next. If you place the level and change it to 3 the next one you place will be 4. The numbering is nothing to be overly concerned about since you can change it to anything you want it to be.
