Revit 2012 takes forever to save
7 REPLIES 7
Message 1 of 8
958 Views, 7 Replies
Since installing Revit Architecture 2012 we have found that even the smallest models take forever to save. It looks like the save completes quickly (by the percentage bar at the lower left corner of the screen) but then the title bar says that it is not responding and it takes several (literal) minutes to come back from the circle of torment. We've also had some Microsoft updates lately that cause us to lose one of our monitors occasionally. Related? Grasping at straws here but the wait while saving is painful.
Configuration in case it will help:
Dell Precision 690
Dual Xeon X5355's
SAS HDs
Dual NVidia Quadro FX 4600's
Win 7 64bit w/ all the latest updates
Files are being saved on an HP MSA 12Tb Array connected to an HP Server running Server 2008
7 REPLIES 7
Message 2 of 8
DarrenP
do you have update 1 installed: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
DarrenP
Message 3 of 8
TorgEng
Found it! I was having the same problem in Civil 3D. The culprit is a system variable: SAVEFIDELITY. I set it to 0 and I'm back in business. It was literally taking over 1/2 hour to save a drawing to my desktop (brand new x64).  WARNING: If you need to keep backward compatibility with 2007 or earlier versions, you may not want to do this. See the article where I got the answer: http://www.dailyautocad.com/2011/03/is-it-taking-too-long-to-save-drawings.html
Message 4 of 8
rosskirby
in reply to: TorgEng
This is the Revit forum, not AutoCAD.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 5 of 8
TorgEng
in reply to: rosskirby
Right, but they're both Autodesk and share some of the same programming. Does Revit not have the global parameter SAVEFIDELITY?
Message 6 of 8
rosskirby
Revit doesn't even have a command line.
Ross Kirby
Principal
Dynamik Design
Message 7 of 8
DarrenP
revit is not autocad
DarrenP
Message 8 of 8
TorgEng
Hm, that's too bad... Sorry for the confusion I thought it did!
