I was working and suddenly my quick access toolbar essentially became transpart so i can barely see it
is there any way to change this?
thanks
can you post an image?
LD
I also have the same problem -- the Quick Access Bar is almost transparent. Also, the Options menu cuts off some of it's info.
However, the same is true of AutoCAD 2012 -- both of which are installed on my new laptop: Dell xps 17", Nvidia graphics card, i7 processor. Maybe Nvidia has to do with this . . . ?
Any ideas will be appreciated!
I had to change my windows theme to anything but Aero. Once I did that a lot of the problems I was having stopped. So give that a try and see how it works.
LD
Thanks that helped with the Quick Access Toolbar!
As for the Options Bar, it still cuts off bottom-half of the words listed in the pull-down menu (when not activated).
