Hi, i´m working with revit 2012 and exporting dwf to open in design review 2013. But when i use the measurement tool in DR the dimension i get is 10 times bigger than the original.
I´ve attached a snapshot of a dwfx with the dimensions from revit and design review, as you can see the dr's dimension is 10 times the revit's. The revit view is in 1:50 scale and i've configured the measure tool in dr to this value. If i configure dr mesaure to 1:5 scale i get the right measure, but this is weird. Tried with a new simple project, just four walls, and got the same error.
I´ve already posted this on Design Review forum and someone suggested that i shoul post it here, since he thinks this could be a problem with the export to dWF process.
Any ideas of what´s going wrong?
Gustavo
Solved by gustavomello. Go to Solution.
When setting units and scale in DR, if i set "units from the drawing from which this sheet was published" to mm and "units to which drawing units will be converted when displaying measurements" to cm i get the correct dimensions in DR.
This doesn´t make sense to me since revit units are set to cm, so i would expect the dwf to read the file in cm too. Is my logic correct? Does revit have a fixed "base" unit (mm) that is tied to the exported files independent of the units set by the user? Or something like that?
