We are running Revit 2012 and have to export all drawings to DWG format for submission to a government department. They have clearly defined requirements for the DWg format. One is that the Titleblock must all be in one AutoCAD block.
Our current exported DWG titleblock produces a titleblock is not in a single block i.e the various pieces of text are separate elements.
Can these be combined somehow in Revit to export as a block?
Thanks in Advance
R
Has this issue been resolved....I'm having the same problems. Or maybe I'm missing something.
I need titleblock to be a block with attributes once exported to .dwg from Revit.....any help would be greatly appreciated.
Hello @Anonymous ,
Thank you for posting! I understand the frustration of not having this ability. This enhancement request has been logged to the Revit Idea board. I urge you to vote and comment on this idea.
https://forums.autodesk.com/t5/revit-ideas/title-block-tags-to-dwg-attributes-export/idi-p/8697620
