Revit 2012 - complex roof
5 REPLIES 5
751 Views, 5 Replies
Could anyone help me with trying to create a curved roof? I want it to be flat apart from where the sloped walls are, the sloped walls are in-place models.
I thought I could do it using swept blend but i'm a little unsure of how to approach it.
I must warn you I'm a bit of a rookie with Revit.
Any help is appreciated.
5 REPLIES 5
Create a flat roof by footprint method.
Then, along the sloping walls, use "edit points" to conform the roof to the wall profile.
cheers
When i try to edit the points it wont let me change them vertically?
You should be able to click the points, and then type in a new value, in reference to your Level.
sorted it, thanks for your help Smiley Happy
Glad it is working.
Please check "New Solution" for this thread.
cheers
