I've recently loaded Revit 2011 on a new desktop machine with Windows 7 and I'm getting a couple of errors that are driving me crazy.
Everytime I click on an element - wall, roof, window, anything - the bar between the toolbar and the display area momentarily becomes 4 or 5 bars, the display shifts and whatever I clicked on moves over a couple of feet.
Also, when I zoom in and out, the screen displays the zoomed-in display and the previous display on top of one another. When I pan, the problem resolves itself.
Also, when I flip from one view to another the screen oftentimes displays the wrong view or displays with the color inverted (black background, white lines). This problem also resolves itself if I pan.
I've had similar problems in the past that have been resolved by either uninstalling the .net framework altogether or installing a previous version of .net. I've tried both with no luck.
Thanks for your help, Mickey
Solved by David_W_Koch. Go to Solution.
You may find this Autodesk Knowledge Network article of interest:
David:
Thank you, this is a good start. I've done #1 as a stop-gap to be able to keep working.
Tried #2, can't get the new driver to download. Says the signature is corrupt. I have a brand new computer with Nvidia Ge Force 720
Tried #3, no luck
Tried #4, no luck
Will try to clean the registry later, I'll keep you posted.
Mickey
Holy S!!! I rebooted my computer and it's fixed. Thanks so much!
The problem was either that I had Revit launched on my secondary monitor or that I had Press & Drag checked.
