Revit 2011 is live
22 REPLIES 22
Message 1 of 23
623 Views, 22 Replies
Revit 2011 is live
FYI, Just downloaded Revit Architecture 2011 from the subscription site.
22 REPLIES 22
Message 2 of 23
LisaDrago
for some reason - the subscription center is now down....
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 23
Autodesk still has not figured out how to maintain their bandwidth!
wrote in message news:6373547@discussion.autodesk.com...
Message 4 of 23
It's doing the same thing as last year - either "access unavailable' or
'wrong password'. Autodesk made downloading the default delivery method,
you'd think they spend a few bucks fixing it
Rick Moore, AIA
www.bgkarchitects.com
Message 5 of 23
Alfredo_Medina
The server seems to be OK. I just downloaded mine. It is 2.59 GB.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 6 of 23
carrucha75
How did you do it?
Message 7 of 23
I guess I just got lucky. Logged on to the subscription site first thing
this morning, noticed it was there, downloaded in about 30 minutes. It
seems now everyone must be trying so the site is bogged down.
"carrucha75" wrote in message news:6373665@discussion.autodesk.com...
> How did you do it?
Message 8 of 23
jmcintyre
Yeah......didn't see that coming.....
Message 9 of 23
So what are the new features listed in the "What's New" tutorial?
wrote in message news:6373634@discussion.autodesk.com...
Message 10 of 23
vector2
there is no problem with the download site for us
who are not subscription members..
Message 11 of 23
Revit Structure 2011 is also up for subscription download. I downloaded it
twice getting the same message that the Download Manager could not verify
Integrity Checks. The "Detail" button on the Download Manager reports 2.64
GB (99% done), status: Fatal Error.
Is this file OK? Anyone else getting this behavior?
Arthur
"cdv" wrote in message
news:6373528@discussion.autodesk.com...
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 5032 (20100415) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5032 (20100415) __________
http://www.eset.com
Message 12 of 23
Alfredo_Medina
Felipe Torres asked:
> So what are the new features listed in the "What's New" tutorial? There you go. Pick your favorite:
User Interface Enhancements
* Modeless Properties Palette
* Repeat last command / Repeat Commands recently used
* Quick Access Toolbar (QAT):
o Single QAT per application
o Increased number of default commands in the QAT
o Customization options via dialog box: move command up/down, add separator, remove command
* Improved access to Worksets and Design Options on status bar
* Ribbon Enhancements:
o Redesigned Modify tab:
+ Consistent modify tools - panels and buttons are always in the same order on the left side of the Modify tab. Buttons enable/ disable as necessary.
+ Modify tab name updates to reflect the active contextual tab appended.
+ Contextual tab content is appended to the right side of the Modify tab when active.
+ Modify and contextual contents are separated by a gray visual bar.
o Persistent access to core modify tools (Object-Action commands):
+ Move
+ Copy
+ Rotate
+ Mirror - Pick Axis
+ Mirror - Draw Axis
+ Delete
o Type Selector Enhancements
Type Selector is combined with the Properties Palette. Open at all times; can be opened/closed using the Properties Palette button available in the Properties ribbon panel.
o Group Edit Mode access
Panel is removed from the ribbon and will float in drawing area when invoked. Default is upper left corner of drawing area and can be moved.
o Model In-Place
Project ribbon replaced with the family ribbon when an in-place model is started or edited. When you finish editing in-place, the ribbon will revert to the project ribbon.
* Improved icons based on user feedback
Large Team Workflow: Linked Models
* Enhancements to the Visibility Control of Worksets in workshared files:
o Visibility by Default for Worksets
o Ability to open/close Worksets for linked models
o Ability to control visibility of linked models according to host model
o Ability to apply View Filters to linked models from host model
* Ability to tag elements in linked files, with the exception of rooms, spaces, and areas
* Ability to automatically generate a ceiling grid from walls in a linked model
* Ability to apply View Filters to linked files
Graphics
* Realistic materials available in editable views
* Hardware acceleration (DX9) on by default
* Levels of Details (adaptive to zoom)
* Ambient occlusion
* Display performance improvements (over 30%)
* Significant performance improvement in display of mechanical and electrical drawings (up to 200%)
Materials
* Protein 2.0 appearances, in single project library
* Increased interoperability with 3ds Max through:
o Export of FBX files to Max with Protein 2 appearances
o Import of DWG files and ADSK files with Protein 2 appearances
Note3ds Max/Design 2011 is required for materials to transfer.
* Support for new realistic display style through Protein 2 materials
* New material classes available in Protein 2, including procedural appearances
Inventor Interoperability
* Support for oval duct, cable tray, and conduit connectors
* Support of new electrical properties (such as Motor)
* Improved performance when importing ADSK files
* Improved AEC Exchange functionality
* Support of Protein materials
Performance Improvements
* Graphics
* MultiCore Operations
* Sync with Central
* Model Open
* User interface reaction time
* Linked Models
DWG Export
* Increased visual fidelity when exporting Revit files to DWG
* Export option for True Color
* Export option for Text treatment
Family Editor Enhancements
* Interactive exploration of parameter values in Revit families
* Ability to lock labeled dimensions
* Reporting Parameters
Parameter Enhancements
* Default parameter type (length vs. text)
* Parameters groups automatically set
Temporary Dimension Enhancements
* Remembering witness lines
* Family Editor: right-click permanent dimensions to select labels
* Ability to control temporary dimension font size and background (transparent or opaque)
3D Alignment Enhancements
* Align tool now works on an element's node, vertex, edge, surface, form, or level
Expanded Region of High Geometric Accuracy
* Previous versions of Revit were unable to maintain the expected level of geometric accuracy at locations farther than 1 mile from the project origin. Revit will now maintain a high level of geometric accuracy for elements placed within 20 miles of the project origin.
Selection Enhancements
* Select All Instances in the current view or in the entire project
Text Notes Enhancements
* Additional leader attachment points: Top Left (TL), Middle Left (ML), Bottom Left (BL), Top Right (TR), Middle Right (MR), and Bottom Right (BR).
* Ability to adjust leader end distance
* Ability to show box around text
* Ability to create bullets and numbering
Sheet Enhancements
* Create new sheet list rows to create placeholder sheets
* Convert placeholder sheets to project sheets
* Grid guide for sheets, enabling consistent sheet creation
Floor Enhancements
* Ability to set span direction for metal deck floors
Analysis
* Sun Path
Interactive tool for visualizing the impact of natural light and shadows on buildings and sites
Conceptual Design Environment (CDE) / Conceptual Form Making and Editing Tool Enhancements
* Solid-Solid Cut: Ability to cut one solid from another solid
* Dissolving Forms: Ability to dissolve a form back to the curves from which it was created.
* Generic mass template
* Flexible component mass
* Sketch Edit mode for Form Profiles
Surface Rationalization Enhancements
* Dividing Surfaces with Intersects by:
o Intersecting levels, reference planes, and lines on reference planes
o Combination of U or V grids and intersects
Subscription Advantage Pack
NoteThe following items were previously released exclusively to Subscription customers.
* Conditional Formatting in Schedule
* Element Section Area and Linear Weight in Schedules
* Span Direction Tool
* DWG Export enhancements (Index color and True Color support)
* Beam Coping for steel beams framed into joined beams and columns
* Text Formatting Shortcuts (Ctrl+B, Ctrl+I, and Ctrl+U)
* Beam System Tags
* Split Walls with Gap
* Keyboard Shortcut UI
* Find and Replace Text in Notes
* Convert between Line Types: Model, Detail, Symbolic
* Export to DWG with correct RGB colors
* Linked File Performance Enhancements
* New API for slope angle and elevation for x,y location in given slab with choice of top and bottom
* Structural Components and Modeling:
o Slanted Columns
o Beam Placement using 3D CAD Geometry
o Curved Beams
o Structural Trusses
o Metal and Structural Deck Assembly
o Control beam length tolerance
o Beam Coping Tool
Revit Extensions
* Shared Parameters Converter
* Model Review
* Autodesk Revit DB Link
* Road and Terrain modules
* Wall framing enhancements:
o New method to choose the location of the studs (wall layers are exposed)
o Multi-selection of walls and openings
User Assistance (Documentation)
* Transition to Web Help, which includes improved search capabilities
* Streamlined Help reference content
* Short Tutorials in video format
* Additional Enhanced Tooltips
* New animated ToolClips
* Improved First Experience
Other Enhancements
* Custom elevation tag
* List sheets not in a project on drawing list
* Background images in renderings
* Sheet layout grid
* Removal of 4 core rendering limit
* Google Maps™ mapping service interface (Location dialog) lets you visualize project locations
Message 13 of 23
jjbjr1990
Got the same message.
Not sure whats up. Down loaded using safari, the file is on the disk, but not sure if it is corrupted.
jb
Message 14 of 23
vector2
king of copy-n-paste -----------> Alfredo
Message 15 of 23
Alfredo_Medina
The height of a wall is not available as a field in schedules, though...
Still, we will need Area divided by Length.
Message 16 of 23
Alfredo_Medina
So what are your favorite new features from that list, Vector, and which of your wishes did not make it?
Message 17 of 23
Alfredo_Medina
One thing I like to see coming back is the ability to use an image as a background in a render. This had been gone with Accurender.
Panoramas did not come back, though.
I like that the mirror options are now separated. It was sometimes annoying to have them in a little drop down list, like in 2010.
I love to have trusses and curved beams tools. I don't have to model them from scratch as before.
A sheet layout grid sounds useful, too.
Message 18 of 23
vector2
but like i've been saying and nobody has been listening-
the complete restructuring of revit began with the 2009
64 bit version and ended with 2010.. the only thing we
are getting now is the continuation of this lame ribbon
and the conceptual design program that nobody is using..
there is nothing else.. the program is going to get
dumbed down for marketing purposes we already
know that..
Message 19 of 23
In addition, I am glad to see that you can now add sheet names and numbers
(without having to create the sheets) for a drawing index. This will be very
useful for adding for consultant's drawings to a drawing list and creating
place holders.
"Alfredo_Medina" wrote in message news:6374060@discussion.autodesk.com...
Message 20 of 23
"nobody has been listening"
ah you are finally getting it, well done.
