Revit 2011 DB Link CADtastrophy!
3 REPLIES 3
CTREVIZO
1165 Views, 3 Replies
Just did an install of Revit 2011 64bit after installing MS Office 2010 64bit (to use Access 64bit database). Uninstalled DB Link & reinstalled it and still same error message, HELP! look at attached.
3 REPLIES 3
CTREVIZO
in reply to: CTREVIZO
well, i went into the folder properties (C:\Program Files (x86)\Autodesk\Autodesk Revit DB Link 2011) and set the permissions to full & removed Read only check box for extra measure & issue solved, somehow?
arxerxes
Thank You!! You are the only one who happens to have had and solved this problem!!
Tags (1)
rosskirby
in reply to: arxerxes
DBLink was trying to keep a log, and the path it was pointed to was a read-only location.  If possible, you might try re-pathing the log file to a folder that wouldn't be read-only, preferably in the project file somewhere, rather than on your machine, so that it's accessible by others.  Just a suggestion.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
