I have a user who is currently running Revit Architecture 2011 Suite with Web Update 2 on a Windows 7 x64 machine with an NVIDIA Quadro 600 and 16GB RAM. The problem is that when she syncs with the central file her program crashes. This happens randomly but at least once a day. I'm at a loss of what to do. The error message produced is not helpful either, well, to me it's not.
Autodesk Revit has stopped working
Windows can check online for a solution to the problem.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Revit.exe
Application Version: 2011.0.2010.903
Application Timestamp: 4c81b6b1
Fault Module Name: RevitDB.dll
Fault Module Version: 2011.0.2010.903
Fault Module Timestamp: 4c81b686
Exception Code: c000041d
Exception Offset: 00000000009d24a9
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 4105
Additional Information 1: 9a57
Additional Information 2: 9a574b6a6a91eadd80079b8d37d2f6de
Additional Information 3: fd84
Additional Information 4: fd844def7c58b07adbeaf056264cb944
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Can you confirm if the project is using Revit Server or standard worksharing?
Also, I would ensure to apply the following hotfix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16767377&linkID=9273944
Thank you,
