I was directed to look at this forum. I am trying to install AutoCAD 2010 but during the installation process, after I get about half way thru, I get the error specfied in the Revit discussion. And I downloaded the file it talked about. But when I try to run it, Windows asks me what program will be needed to run this "fix it" program. Does this fix it work for AutoCAD 2010 as well as Revit? I am still down with no ACAD to work with. I know this is a free program for professionals that are un-employed but I still can't do anything? Help me? Am I in the wrong forum? All I want to do is install the program that I took 3 hours downloading and run it. Thanks very much.
Hi William,
This is an older thread that started before the Installation & Licensing forum was set up - I would suggest reposting your message in that forum : http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24.
