Hello Guys,
i amended family door and added door Knob. The door family looks ok in any elevation view. But when i load as load family and created section thru door the other door knob is away from door panel. What do i need to change?
Please find enclosed.
Thank you..
Solved by alan.quinn. Go to Solution.
What’s the handle locking too in the family? I’m guessing that it’s not aligned and locked to the correct ref plane and as such appears as if it’s hovering. Also, what thickness is the wall in the family editor? Is the wall in the project the same? If not and you change the wall thickness in project to match the family does the handle look correct? Again, if so, check what the handle is aligned and locked too.
Let me know your results and thanks for posting.
Hi Allan,
I followed your instructions and its look okey now. Thanks a lot for your help. Very much appreciated.
God Bless.
