One option that may work is : Save as a new project. Make sure you check the save as a central file option under the options tab. Print from this new file and then save back to original. Important: when you save back to original project, make sure no one else is working on it.
I'm glad this worked for me, because my last option was to update to a newer version ( I'm lucky that our office has several versions.). That would have been caos with our consultants.
I hope it works
I had similar experience with one sheet not printing and causing crash. The sheet had a view with an imported raster image. The solution I found was to adjust print setting from vector processing (faster) to raster processing, and it worked.
See if that helps,
Good luck
