-Permission acces to the server?
-Under a student account can you browse to the server on the net work?
-Also try entering the IP of the server or the server name(wich ever one you
are not working with).
-Check your client registry enteries in the computers people are logged
onto.
-Check that local software firewall is down(I'm not saying keep it down,
just try it down).
-Do you have the most recent version of FlexLM?
-Do a status report on the server and check for any error codes.
wrote in message news:5701549@discussion.autodesk.com...
I'm currently responsible for the implemetation of AutoCAD Revit 2008 within
a highschool. I'm having trouble however getting the licencing to work. This
has been a problem for a while and has been assigned to me recently due to a
leaving co-worker. To resolve this problem I have built a virtual server
from scratch based on windows server 2003 with Service Pack 1 and then the
version of FlexLM that was included with the product. I have imported the
licence file and everything seems to be ok until I try to obtain a network
licence from within Revit. An error 1.5.-5 shows up saying a licence could
not be obtained. The strange thing is that within our productionnetwork,
some clients are able to obtain a licence. Any help would be greatly
appreciated! Log files below...
Status
Flexible License Manager status on Wed 8/15/2007 10:07
[Detecting lmgrd processes...]
License server status: 27000@TS0113
License file(s) on TS0113: C:\Program Files\Autodesk Network License
Manager\License\Revit2008TS0113.lic:
TS0113: license server UP (MASTER) v11.4
Vendor daemon status (on TS0113):
adskflex: UP v10.8
Feature usage info:
Users of 54700REVITS_2008_0F: (Total of 60 licenses issued; Total of 0
licenses in use)
Users of PLIST: (Total of 1 license issued; Total of 0 licenses in use)
Diagnostics
FLEXnet diagnostics on Wed 8/15/2007 10:07
License file: C:\Program Files\Autodesk Network License
"54700REVITS_2008_0F" v1.000, vendor: adskflex
License server: TS0113
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
"PLIST" v1.000, vendor: adskflex
DebugLog:
0:06:40 (lmgrd) -----------------------------------------------
10:06:40 (lmgrd) Please Note:
10:06:40 (lmgrd)
10:06:40 (lmgrd) This log is intended for debug purposes only.
10:06:40 (lmgrd) In order to capture accurate license
10:06:40 (lmgrd) usage data into an organized repository,
10:06:40 (lmgrd) please enable report logging. Use Macrovision's
10:06:40 (lmgrd) software license administration solution,
10:06:40 (lmgrd) FLEXnet Manager, to readily gain visibility
10:06:40 (lmgrd) into license usage data and to create
10:06:40 (lmgrd) insightful reports on critical information like
10:06:40 (lmgrd) license availability and usage. FLEXnet Manager
10:06:40 (lmgrd) can be fully automated to run these reports on
10:06:40 (lmgrd) schedule and can be used to track license
10:06:40 (lmgrd) servers and usage across a heterogeneous
10:06:40 (lmgrd) network of servers including Windows NT, Linux
10:06:40 (lmgrd) and UNIX. Contact Macrovision at
10:06:40 (lmgrd) www.macrovision.com for more details on how to
10:06:40 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:06:40 (lmgrd) for your enterprise.
10:06:40 (lmgrd)
10:06:40 (lmgrd) -----------------------------------------------
10:06:40 (lmgrd)
10:06:40 (lmgrd)
10:06:40 (lmgrd) pid 504
10:06:41 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:06:41 (lmgrd) Done rereading
10:06:41 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on TS0113
(IBM PC) (8/15/2007)
10:06:41 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or
Macrovision Corporation. All Rights Reserved.
10:06:41 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:06:41 (lmgrd) World Wide Web: http://www.macrovision.com
10:06:41 (lmgrd) License file(s): C:\Program Files\Autodesk Network License
10:06:41 (lmgrd) lmgrd tcp-port 27000
10:06:41 (lmgrd) Starting vendor daemons ...
10:06:41 (lmgrd) Starting vendor daemon at port 2080
10:06:41 (lmgrd) Using vendor daemon port 2080 specified in license file
10:06:41 (lmgrd) Started adskflex (pid 756)
10:06:41 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
10:06:41 (adskflex) lmgrd version 11.4, adskflex version 10.8
10:06:41 (adskflex) Server started on TS0113 for: 54700REVITS_2008_0F
10:06:41 (adskflex) PLIST
10:06:41 (lmgrd) adskflex using TCP-port 2080
10:06:47 (adskflex) TCP_NODELAY NOT enabled
