Revision properties
3 REPLIES 3
416 Views, 3 Replies
Revision properties
hi, why I cant create a new parameter in Revision properties?
thanks
3 REPLIES 3
L.Maas
I know, that is the way it is at the moment. It is on the wishlist of many people.
HERE is a page site from autodesk where you can submit your comments/requests.
Louis
Please mention Revit version, especially when uploading Revit files.
s.koulis
The way we have worked around this in the past is join 2 fields in one and use the other for a new parameter. For example we joined the "Drawn by" & "Checked by" fields to one "Drawn / Checked" and filled both names in a single field seperated by "/". This way we could use the other field to add the revision code we are using which contains both numbers and letters.
Hope this gives you an idea to workaround your issue.
in reply to: s.koulis
thanks, it's a good idea
