Reviit 2014 Window Insertion
3 REPLIES 3
elliot.board
208 Views, 3 Replies
I am trying to make my windows cut through three seperate walls but am having great difficulty! Below is an image of the walls i need the window to cut through.
Please help and thanks in advance!
3 REPLIES 3
gustavomello
in reply to: elliot.board
never tried with three, but with two you just have to host the window on the wall where it'll be placed and join the other wall.
If you can't or don't want to join the walls, i think you'll have to create a void, long enough to reach the farthest wall, in the window family and use cut, selecting the window and the other walls, in the project.
Gustavo
L.Maas
In addition to Gustavo's answer. Joining with more than two walls work. Instead of a void you copul use a wall opening.
Ohterwise you could consider making a single wall.
Louis
Please mention Revit version, especially when uploading Revit files.
elliot.board
in reply to: L.Maas
Thanks both of you! both answers were of great use!
Elliot
