Reveal line weights
7 REPLIES 7
Message 1 of 8
twilks1
4149 Views, 7 Replies
Reveal line weights
How do you control the line weights of wall reveals in 2011?  The default is way to heavy for our need and I see no way to modify this.
7 REPLIES 7
Message 2 of 8
ryan.duell
in reply to: twilks1
I have included 2 options to modify the appearance of a wall reveal below:
1.  VG > Walls > Projection/Surface
Typically the reveal is included in the V/G > Walls > Projection/Surface setting.  You should be able to toggle the lineweight as needed here.  Or you could do on an element basis, by right-clicking element > Override Graphics in View > By Element > Projection Lines:
2.  Linework Tool
Reveals can be overridden with the linework tool as other element types:
Video Example: http://screencast.com/t/NjhlNjc5
2.  Linework Tool
Video Example: http://screencast.com/t/YmM2YTM1MWIt
Ryan Duell
Message 3 of 8
twilks1
in reply to: ryan.duell
The Linework tool is an option if you only have one (or few) reveals but not with many considering all the views and changes that may be affected. The element basis for an override does not work with reveals (but does for wall sweeps) and the Override Graphics in view for projection lines on walls affects the entire wall, not just the reveal so it is not an option either. I suppose the only answer is a hybrid combination of the above functions until Autodesk realizes they only need to add a similar category in the view visibility controls, like the Wall Sweep category.
Message 4 of 8
donnia
So this has seriously NOT been fixed at all yet? My reveals as added objects of the wall family causes so much more work. They look great for renderings, show up in sections, but in elevation I have a big blob of a line with embeded 2" reveals.
This has been on the wishlist for a while also. Please keep us posted on when this will be fixed.
Message 5 of 8
adalzell15
in reply to: donnia
Still not fixed huh? AUTODESK!! How many years!!! The reveal tool is useless if if makes elevations impossible to read without relying on using the lineweight tool to fix the lineweights. It would be great if you could control the visibility graphics like you can for wall sweeps but at this point it is just a tease. It would be perfect for exterior panel reveal lines...
Message 6 of 8
shigeru6XRL7
Still not fixed...?
Message 7 of 8
semhustej
in reply to: shigeru6XRL7
Yes, still no fix. You can find some workarounds here:
https://forums.autodesk.com/t5/revit-architecture-forum/lineweight-override-of-reveals/td-p/6645841
Is there Revit Idea post about this problem? I didn't see any. It might be worth the effort to create one.
Tom
Message 8 of 8
Darin_HDR
The easiest work around I have found is to select the wall(s) with reveals and change the projection lines by using the Override the Element tool. This will change all the reveal lines and then you only have to use the linework tool on the selected walls to fix the wall outlines, instead of ALL walls (like you would have to do if you used the VG overrides on the wall projection lines).
Not a good fix, but maybe a little better than any other suggested.
And I'll add to the chorus...what the hell Autodesk, you still haven't fixed this yet.
