Revit Architecture
Active Contributor
twilks1
Message 1 of 4 (1,171 Views)
Reveal line weights
1171 Views, 3 Replies
08-23-2010 03:09 PM
How do you control the line weights of wall reveals in 2011?  The default is way to heavy for our need and I see no way to modify this.
Employee
ryan.duell
Message 2 of 4 (1,147 Views)
Re: Reveal line weights
08-24-2010 06:57 AM in reply to: twilks1
I have included 2 options to modify the appearance of a wall reveal below:
1.  VG > Walls > Projection/Surface
Typically the reveal is included in the V/G > Walls > Projection/Surface setting.  You should be able to toggle the lineweight as needed here.  Or you could do on an element basis, by right-clicking element > Override Graphics in View > By Element > Projection Lines:
2.  Linework Tool
Reveals can be overridden with the linework tool as other element types:
Video Example: http://screencast.com/t/NjhlNjc5
2.  Linework Tool
Video Example: http://screencast.com/t/YmM2YTM1MWIt
Ryan Duell
Revit Clinic
@revitclinic
Active Contributor
twilks1
Message 3 of 4 (1,130 Views)
08-24-2010 11:16 AM in reply to: ryan.duell
The Linework tool is an option if you only have one (or few) reveals but not with many considering all the views and changes that may be affected. The element basis for an override does not work with reveals (but does for wall sweeps) and the Override Graphics in view for projection lines on walls affects the entire wall, not just the reveal so it is not an option either. I suppose the only answer is a hybrid combination of the above functions until Autodesk realizes they only need to add a similar category in the view visibility controls, like the Wall Sweep category.
Member
donnia
Message 4 of 4 (786 Views)
01-31-2012 07:20 AM in reply to: twilks1
So this has seriously NOT been fixed at all yet? My reveals as added objects of the wall family causes so much more work. They look great for renderings, show up in sections, but in elevation I have a big blob of a line with embeded 2" reveals.
This has been on the wishlist for a while also. Please keep us posted on when this will be fixed.
