Restore missing south elevation view
2 REPLIES 2
badincite
4380 Views, 2 Replies
Is there anyway to re-create the south elevation view not sure where it went.
2 REPLIES 2
Alisder.Brown
in reply to: badincite
Hey
In your plan view do the following
"View" tab "Create" panel > "Elevation" > Place the elevation
Then simply select the elevation you placed and tick the orientation you want to be viewing. Rename the view and apply view template as required
hope this helps
Alisder Brown
Senior BIM Coordinator
Scotland, UK
in reply to: Alisder.Brown
Another way is to copy paste it from a template
Also may I suggest you take a look at this post where I have collected all kind of tips about finding things in Revit:
http://danielgijsbers.blogspot.nl/2014/02/revit-object-visibility.html
