Resolving "Invalid Formula" for Yes/No parameter
12 REPLIES 12
Message 1 of 13
1772 Views, 12 Replies
Hello, I am having issues with the Yes/No formula. I am trying to create multipule formulas for a backsheet and I've had success with two of them, however when I go to the next formula it continues to tell me "Invalid Formula." I am using the "not()" formula.
Thank you.
12 REPLIES 12
Message 2 of 13
CoreyDaun
Hello, welcome to the Discussion Groups!
We'll need a little more information to be able to help. What version of Revit are you using? Can you post the formula you're working with?
Message 3 of 13
in reply to: CoreyDaun
I am using revit Architecture 2013 and the formula I am using is the not formula ex. not(1), does that help?
Message 4 of 13
CoreyDaun
Within the NOT function, there has to be an expression that returns a TRUE/FALSE result. A few examples:
= not(Number = 1)    ---> where "Number" is a Number or an Integer type parameter
= not(Length1 > Length2)
= not(Checkbox)    ---> where "Checkbox" is a Yes/No type parameter
If you still need some help, can you explain what you're trying to accomplish with this formula?
Message 5 of 13
What I am attempting to do is a backsheet for the office I work for, and in this backsheet there are yes no boxes. What I am having a hard time with is getting the yes no formula to work correctly. I want the yes box to be active and for the no box to be checked off, and vise verse. When yes is off no is on.
Message 6 of 13
CoreyDaun
That's most easily done when there are only two Yes/No parameters involved. One of the Parameters will be user-controlled and the other will be dependent on the first. Example:
Parameter1 & Parameter2 are both Yes/No type parameters.
Parameter1 will not have a formula assigned to it. This will be the controlling parameter.
Parameter2 will have the formula: "not(Parameter1)"
Message 7 of 13
This formula is only being accepted by one parameter and is working perfectly. However when I use this formula for the next parameter it's telling me "Invalid Formula." How I have it is:
Zoning (YES) is controlling Zoning (NO) with the formula not(Zoning (YES)), that the only parameter that is accepting the formula when I go to the next set of parameters that need the formula it will not accept it.
Message 8 of 13
I can attach the file that I am working on for better clarification.
Message 9 of 13
CoreyDaun
The problems here lies with the parentheses is the Parameter Name. If they've got a formulaic symbol in their name (i.e. minus, parentheses, asterisk) then it will be treated as such by Revit. So, for example, say you have:
Parameter Name 1 = Total_Length
Parameter Name 2 = Option - Type A
Parameter Name 3 = Length (Total)
...and you wanted to add these values together with a formula: Total_Length + Option - Type A + Length (Total)
Because of the "-" in the Parameter name, Revit thinks that "Option" and "Type A" are two separate parameter names.
Total_Length [plus] Option [minus] Type A      ...returning an error.
Because of the "()" in the Parameter name, Revit thinks that "Length" is a function and that "Total" is a separate parameter name.
Option - Type A [plus] Length(Total)      ...returning an error since "Length" isn't a valid function.
In lieu of a hyphen, I  instead use the "En Dash" character for Parameter Names. Alt+0150 = "–"
If you need to keep the parentheses in the Parameter Names, then you can use the "ornate parentheses" found in the Character Map for the Arial Font.
Message 10 of 13
I just happened to figure it out. For some reason revit would not accept the formulas being inputted from top to bottom. When I started to insert the formulas from bottom to top revit accepted them in. Very strange to say the least and I hope this is fixed in, or made better in 2014, but thank you nonetheless for the help.
Message 11 of 13
One other question I have is, is there a reason as to why when your inserting parameters in a family that revit orders them in reverse order?
EX:
When I enter parameters in as 1,2,3,4,5,6
Revit then lists them in order of 6,5,4,3,2,1. Is there a way to fix this and reorder the parameters in the Properties box?
Message 12 of 13
CoreyDaun
Honestly, I've no idea why Revit prefers reverse-alphabetical order, but I believe that's been an outstanding issue since day one. Furthermore, the sort order is based upon the Parameter name when it is first created, so renaming them does not change the sort order. There is a semi-convoluted method of controlling the sort order of these parameter; you can find it by searching this forum using the term "Parameter Order".
Message 13 of 13
Awesome! Thank you for your help!
