Viewports - ick. Crop Regions Rule. ;-)
Unfortunately, crop regions are not saved as part of a View Template. View
Templates only store information not specific to model geometry. A crop
region needs to know what and where to crop.
However you can turn on crop regions for multiple views at the same time
once the views are on the sheet. Just select all the views on the sheet and
open the Properties dialog. Toggle the Crop Region option so it is a black
check and you are done. Each crop region can then be individually sized to
meet the needs of each particular view.
"Jeffrey McGrew" wrote in message
news:40c674d6$1_2@newsprd01...
> TDKD wrote:
> > I'm trying to add four views on a A3 sheet, one of the views had to be
resized a little but its vewport remain same. Is it possible to resize
vewports as well? I know I use to be able to create and add many viewports
in ADT, can I add more than one in a single command in Revit?
> Yes. When you place a view on a sheet, Revit will assume a default
> 'viewport' (to use ACAD/ADT terms) border to that view. If you instead
> open/activate that view, go to view properties and select for it to
> have a view crop region, then you'll have a user-created border around
> that view that you can drag around (kinda like an xclip). Then you can
> select for said border to not be visible in the same view properties,
> and it won't show up, but continue to properly crop the view.
> To apply this change to multiple views, create a view template with
> the desired settings, and then apply that to the views you want to
> follow those settings. I think you can do this to more than one view
> at a time to 'batch process' them all to the same settings, but I
> might be mistaken about that.
> Jeffrey McGrew
> Application Specialist BSD
> AEC Technologies, a division of ID8 Media Inc.
> (415) 593-6000 x 129
> (415) 593-3333 Fax
> (415) 505-4689 Cell
> www.aectech.com
> www.id8media.com
