As a former user of another CADD platform, I enjoyed the checkbox that allowed you to "adjust dimensions and text with scale" or some similar wordage.
This allowed you to print images at different scales without having to change all of your annotations, whatever they may be.
Wish list item.
Thanks.
AutoDesk;
For me, scaling text means changing its size. Was wondering why REVIT doesn't have the option (like a checkbox) to scale font size when changing drawing scale...for annotations, dimensions, tags, etc. It'd be best if tags, section markers, elevation markers, etc. changed with scale change as well.
Would love to see that sooon if there's no workaround available now.
Revit text and dimensions are based off of the Sheet size of 1:1.
So when you scale a view to a different size, the existing text and dimensions are going to remain the sheet size. So if you want a smaller text, then you need to create a smaller text style. But will it be readable when you place it on a sheet?
If this is applying to 1/2 size sheets...print at 50% from a full size sheet, don't create 1/2size sheet views like you did in Autocad.
I know what you're talking about, I guess I need to rephrase my question to a REVIT user's form of thinking from that of the software I used to use. I'll get back to you on it when I have a little time to go back and better explain. Thanks for your time and consideration.
