Can anyone tell me why my existing walls show up fine in my sheet but don't plot to .pdf
I have the view range settings set correctly and all other sheets plot fine.
I thought maybe the roof transparency was the issue but
Revit is usually pretty much a WYSIWYG plotting operation and the walls are displaying in the sheet file.
Haven't tried plotting to a plotter but it doesn't matter. I need to plot .pdf's
Not sure what I'm missing here.
I'm in 2013.
Please see attached files.
Thank You.
what pdf printer have you instaled?
I have PDF Creator and Bullzip PDF Printer and both of them work fine...indeed WYSIWYG....
Constantin Stroescu
when you make the settings try from Setup ...RASTER PROCESS not Vector Process option....I made a try and it looks that they have different result
Constantin Stroescu
Constantine,
That did the trick but I would definitely call that a workaround since I shouldn't have to change to raster to get it to plot correctly. Thank You for the fix but I'd still like to know why this is happening and how to prevent it.
Not sure if it's just a .pdf issue but when I complete the project tomorrow I'll find out.
Thanks Again.
