Revit Architecture
Revit Architecture
Member
philip
Message 1 of 4 (313 Views)
Rendering with Autodesk 360 from Revit LT 2014 with a transparent background
313 Views, 3 Replies
03-17-2014 03:29 AM
I am wanting to create a rendered Tiff image with a white/transparent background- no sky image or colour.  Even when I select None for Background under Graphic Display Options it still includes a sky background in the rendered image.
I'm not sure if or how the option for Alpha (Transparency Background) in the Rendering in the Cloud options relates to this issue.
Any thoughts?
I'm Using
Revit LT 2014 on subscription
You can render with sky as alpha by selecting that option in the Autodesk360 popup menu. Doing so replaces sky with a flat color easily made into alpha in Photoshop or Gimp. hope that helps
New Member
info
Message 2 of 4 (298 Views)
Re: Rendering with Autodesk 360 from Revit LT 2014 with a transparent background
03-17-2014 04:52 AM in reply to: philip
Member
philip
Message 3 of 4 (269 Views)
03-17-2014 03:48 PM in reply to: info
Many thanks.
When I have tried this setting it still produces an image with the sky background.  Is it only once you have it in photoshop etc that you can change it to a blank background?  When I opened one in GIMP it didn't appear to have any layers.  I don't really understand the alpha thing so don't know how to "make it into alpha" or what that means.
Thanks again for your help.
Member
philip
Message 4 of 4 (255 Views)
03-18-2014 04:01 AM in reply to: philip
I have the outcome I was after.  I think the "Alpha (Transparency background)" check box was the key to it.
Thanks again
