Hi all,
I am using Revit 2010 and when I want to render a region I often have to zoom out to redefine the boundary of the region. I think this can be improved upon so that you could, say, click on a button in the render dialogue box to reset the region to approx 75% the size of the drawing area.
I think that this would be really useful as I like to test the rendering for materials etc of small areas of the model so I don't waste time doing the whole rendering and getting some of it wrong.
Cheers,
Raoul
Solved by Jillian.Bejtlich. Go to Solution.
That is a great suggestion! If you could, please submit a wish list request at http://usa.autodesk.com/adsk/servlet/index?siteID =123112&id=1109794. Information submitted through that link goes to the Revit development team and is considered for future implementation.
Thanks!
So you are saying that you have rendered output on tap?
What I am saying is that to reduce wasting valuable time rendering a whole model I would like to see that a portion of it will look exactly how I want it to look. Which was probably not clearly explained in my initial post.
Raoul
Wow, that's amazing! Unfortunately I have slow PC so I don't have the benefit of 3 minute renderings, hence the suggestion.
