Rendering problem
6 REPLIES 6
poxil
343 Views, 6 Replies
Rendering problem
Hello, Im haiving problems witn my rendering,  yesturday everithing was working fine but today everytimie i set rendering quality higher than draft, Revit either fails to render (rendering area goes black) or the pc crashes and i get bluescreen.
6 REPLIES 6
DarrenP
in reply to: poxil
probably not a revit issue
thats a hardware problem most likely
your probably overheating the computer
DarrenP
poxil
in reply to: DarrenP
I dont think so, as i said everything was warking fine. It goes to 10% of render in less than 10 seconds then it thinks a bit  and it goes to 100% full complete render which is black...
My pc is intel i7 3.5ghz, 8gb ram and gefoce gtx680. I checked out the temperatures during the process and its slightly above 60.
I got message from revit: Unknown error occured...
jz4all
in reply to: poxil
Hi
I experienced  such a thing time ago. But after restarting my computer twice, everything turned back fine.
Verify your graphics card, maybe it is not good enough for such mission!!!
DarrenP
in reply to: jz4all
have you looked up the blue screen error
that will tell what the problem is
its not going to be revit
DarrenP
DarrenP
go by this guide: http://www.pcworld.com/article/2023665/anatomy-of-a-pc-crash-7-scenarios-and-how-to-avoid-them.html
DarrenP
poxil
It is not happening in other projects, only in this one, blue screens are not showing up anymore, it just doesnt render.
