Revit Architecture
Re: rendering material lines
05-15-2010 03:44 PM in reply to: ThomasMC
The editor that vector2 showed you earlier is not available in 2010. As
Jeff stated in his response it was changed in 2011. So unless you are going
to upgrade to the newer version you will not have access to that. Sorry.
"ThomasMC" wrote in message news:6392077@discussion.autodesk.com...
> I am using Revit 2010. When I go to the Materials dialog and then to the
> the render appearance tab as in your screen capture there is no option for
> the grout lines. I see no lines in my renderings for the grout just a flat
> white surface that looks more like a painted concrete floor than a tile
> floor. How can I see the surface lines in rendering from Revit 2010?
Employee
0 Kudos
Post 12 of 12
05-16-2010 05:59 AM in reply to: ThomasMC
I'm not that familiar with Revit 2010 but if this is a texture-mapped material, try increasing the Bump; this map is usually a black-white inverse of the original texture map, so increasing it may pop out the grout lines more.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
