rendering material lines
11 REPLIES 11
Message 1 of 12
ThomasMC
1071 Views, 11 Replies
How can I get the grout lines of floor tiles or the lines of any materials to show up when rendering?
11 REPLIES 11
Message 2 of 12
vector2
in reply to: ThomasMC
> {quote:title=ThomasMC wrote:}{quote}
some images you just render as is-
others you can edit..
Message 3 of 12
ThomasMC
How do I get to the texture editor dialog box in your image? Is that in Revir Architecture 2010?
Message 4 of 12
vector2
it's in the materials dialog..
if you are using the ribbon it's under
the manage tab.. Edited by: Discussion_Admin on May 15, 2010 2:49 PM
Message 5 of 12
The editor shown in the image is not in frevit 2010. The materials editor
was modified in 2011.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
wrote in message news:6392071@discussion.autodesk.com...
Message 6 of 12
vector2
they never said they were using 2010..
Message 7 of 12
In the post you responded to they implied they were using 2010. At least
they asked if your original image came from 2010 (which it did not). Your
response could have beeen a bit more clear rather than just telling them
where the material editor is found.
Jeff Hanson
Autodesk - BIM UX
Manchester, NH
wrote in message news:6392116@discussion.autodesk.com...
Message 8 of 12
vector2
you are right.. i failed to make
that assumption..
Message 9 of 12
vector2
here is where you want to go if you are using revit 2010..
Message 10 of 12
ThomasMC
I am using Revit 2010. When I go to the Materials dialog and then to the the render appearance tab as in your screen capture there is no option for the grout lines. I see no lines in my renderings for the grout just a flat white surface that looks more like a painted concrete floor than a tile floor. How can I see the surface lines in rendering from Revit 2010?
Message 11 of 12
The editor that vector2 showed you earlier is not available in 2010. As
Jeff stated in his response it was changed in 2011. So unless you are going
to upgrade to the newer version you will not have access to that. Sorry.
"ThomasMC" wrote in message news:6392077@discussion.autodesk.com...
Message 12 of 12
ShanaProd
I'm not that familiar with Revit 2010 but if this is a texture-mapped material, try increasing the Bump; this map is usually a black-white inverse of the original texture map, so increasing it may pop out the grout lines more.
Rail Community
