I am Using Revit Architecture 2012 and I am trying to render an interior perspective in Revit using the built in rendering process and I can get them to look OK, but I am having trouble with little white square that seem like a reflection issue. I can not get them to go away. Is there a setting that I am not doing right. Any guidance would be helpful. I attached two images to show what I am talking about.
Andrew Risch
Try a couple of things:
1. In the Materials that are getting the bad effect, change them to a "less glossy" setting like "matte" finish.
2. Set the render settings a bit higher, esp. antialiasing which may help lessen the bad effect.
Play with the exposure controls as well--after a quick test rendering at first, then as you get a better result
change it before rendering.
Also play with the intensity and other settings of the artificial lights--they can cause odd effects on materials
and reflections/refractions.
cheers
