You can set the phase filter of the view to "show complete" and then render.
This will use the material assignments used by the category or element
rather than the overidden value for the pahse.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
wrote in message news:6390257@discussion.autodesk.com...
I have just set up a project and everything at the moment is existing. I
want to render this, however everthing renders gray. I have gone into
Manage>Phases>graphic Overrides and changed the Material to Phase- New for
existing items. That did not help. What do I need to set to get existing
objects to render as new?
Wiley
