Render "interior artificial only" problems
3 REPLIES 3
diegoratia
2236 Views, 3 Replies
Im trying to improve this kind of render, but at least two things are driving me crazy.
One is the "noise" in the picture and the other is the lines created by lights. In order to explain myself better I attach a picture.
I would be very grateful if someone teach me how to improve this.. Thanks in advance.
3 REPLIES 3
L.Maas
in reply to: diegoratia
Rendering is not easy, in many cases more art than science. To get good results is dependent on many factors.
Some will say that you would have to use a better renderer (e.g. by using 3DS Max).
However you should be able to get better results with Revit. I do not know what your level of experience is with rendering.
Have you tried different render quality settings? In the settings you can go from Draft to Best (and custom).
You should experiment with these settings.The higher the settings the longer the render wiil take. In cases it will take a long time you can do partial renderings (regions) and focus on areas of concern.
It might be good to do render experiments and try different custom settings to see the differences.
For your lights it might also be a render setting. However it can also be the lights itself. Have you looked at the photometrics settings of your light? In some case you might even want to change the light family itself and change to a Photometric Web File (IES). As a final point it might also be the (floor) materials. Try different materials and see if you get less noise.
As a first step I would look at your render quality settings.
Louis
Please mention Revit version, especially when uploading Revit files.
diegoratia
in reply to: L.Maas
First of all, thank you for your answer. That was very complete.
I tried a lot of things with the settings before I decided to come here for help. I read some topics about rendering settings when you want interior and artificial lights and nothing changes. I think its not about render settings.
So I've come to the conclusion that the problem is both photometrics settings and the floor material. I dont know much things about photometrics settings so I'll try different things and ill find some information in order to learn about this.
About the floor material, i want mine to be some kind of polished concrete, and something must be wrong. The thing is that I rendered the same view with interior sun only and things went pretty nice for me (I'm just a student trying to improve my revit skills).
Anyway, thanks for your attention, very helpful.
diegoratia
It really was the material. I made some changes in the sttings of material, bright and gloss, polished to semi-polished and it got better i think.
Still working on light lines.
