Revit Architecture
Active Contributor
0 Kudos
Post 1 of 3
Render floor plan views?
2253 Views, 2 Replies
08-21-2004 04:06 PM
Is it possible to render floor plan views and have a 2d drawing with shadows and advanced lighting instead of shaded views?
(instead of exporting the model in 3d packages which is a bit problematic rendering top views and then combining pdfs with jpgs)
If not, are you planning to intergrate something like that in future releases?
Thanks in advance,
best regards
mike
*Jeffrey McGrew
Post 2 of 3
Re: Render floor plan views?
08-21-2004 07:00 PM in reply to: mthemelis
First, make a normal non-perspective 3D view. Then, go into the view properties and turn on the Section Box. Drag the handles of the Section Box around to crop your model however you like. Then go to the View->Orient->Top view to auto-rotate the view to a plan view. Finally, render away! Jeffrey McGrew mthemelis wrote: > Is it possible to render floor plan views and have a 2d drawing with shadows and advanced lighting instead of shaded views? > > (instead of exporting the model in 3d packages which is a bit problematic rendering top views and then combining pdfs with jpgs) > > If not, are you planning to intergrate something like that in future releases? > > Thanks in advance, > best regards > mike
Active Contributor
0 Kudos
Post 3 of 3
08-22-2004 10:55 AM in reply to: mthemelis
ok, thank you very much.
best regards,
mike
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
