Render floor plan views?
4 REPLIES 4
mthemelis
13358 Views, 4 Replies
Is it possible to render floor plan views and have a 2d drawing with shadows and advanced lighting instead of shaded views?
(instead of exporting the model in 3d packages which is a bit problematic rendering top views and then combining pdfs with jpgs)
If not, are you planning to intergrate something like that in future releases?
Thanks in advance,
best regards
mike
4 REPLIES 4
in reply to: mthemelis
First, make a normal non-perspective 3D view. Then, go into the view properties and turn on the Section Box. Drag the handles of the Section Box around to crop your model however you like. Then go to the View->Orient->Top view to auto-rotate the view to a plan view. Finally, render away! Jeffrey McGrew mthemelis wrote: > Is it possible to render floor plan views and have a 2d drawing with shadows and advanced lighting instead of shaded views? > > (instead of exporting the model in 3d packages which is a bit problematic rendering top views and then combining pdfs with jpgs) > > If not, are you planning to intergrate something like that in future releases? > > Thanks in advance, > best regards > mike
mthemelis
ok, thank you very much.
best regards,
mike
dcnkzr
So Can we render floor plans with scale .ro example I would like to render my site plan with 1:200 scale .
cbcarch
in reply to: dcnkzr
No.
But, you can save the image, lay it over a scaled floor plan and scale/adjust it to fit over the floor plan.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
