Renaming exisiting parameters- Assembly Code
3 REPLIES 3
671 Views, 3 Replies
Is there a way to rename the Identity Data Parameter- Assembly Code?
3 REPLIES 3
Alfredo_Medina
No. Some parameters are kind of hard coded into the families, and cannot be changed.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
WorkerBeeatDDP
just make your own shared parameter and use that instead. My is called AssblyCode
Dave - DDP
Acad 2012 and Revit 2012
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
you can.
follow instructions as per the link below (basically editing a .txt file (uniformatClassifications.txt file)
https://assemblesystems.zendesk.com/entries/23311043-Customizing-Assembly-Codes-and-Assembly-Descrip...
worked for me. i had concrete piles with the assembly description as steel pipes (for some reason)
i closed my revit sessionI, went into the aformentioned .txt file and changed it to concrete.
apologies if i'm talking out of my left ear and misinterpreted what you mean.
Pete
Rail Community
