Revit Architecture
JamaL9722060
Message 1 of 6 (652 Views)
Removing tag leader,
652 Views, 5 Replies
10-03-2012 01:43 PM
I couldn’t know how to remove the leader of the tag from its family. How this might be done?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
LisaDrago
Message 2 of 6 (638 Views)
Re: Removing tag leader,
10-04-2012 04:35 AM in reply to: JamaL9722060
The leader is an automatic and can't be turned off - in the options bar you can uncheck Leader and then it will not place a leader. Circled below...
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
JamaL9722060
Message 3 of 6 (620 Views)
10-05-2012 01:44 AM in reply to: LisaDrago
many thanks for the answer.
but why there is way to edit its family and thus we can choose it to be off by default?
Firefox 20.0,
Kaspersky 2013.
LisaDrago
Message 4 of 6 (610 Views)
10-05-2012 05:22 AM in reply to: JamaL9722060
I don't have a better answer other then it is how the system works. You can create any type of tag you would like - but you will always have a leader option available.
LD
JamaL9722060
Message 5 of 6 (600 Views)
10-05-2012 08:13 AM in reply to: LisaDrago
many thanks. however, it works.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
New Member
velcrorobot
Message 6 of 6 (410 Views)
06-18-2013 11:34 AM in reply to: JamaL9722060
There's away to remove tag leader in bulk.
1.  SELECT SINGLE FAMILY INSTANTE
2. RIGHT CLICK, SELECT ALL INSTANCES IN VIEW OR IN PROJECT
3.  WHILE SELECTION IS HIGHLIGHTED TO GO TO ANNOTATE MENU AND CHOOSE TAG ALL
4. DIALOG BOX OPENS WITH DIFFERENT TAGS IN PROJECT
5.  SELECT THE TAG YOU WANT TO USE AND IN THE LOWER LEFT HAND CORNER THERE IS A CHECKBOX THAT SAYS LEADER.  LEAVE IT UNCHECKED AND ALL OF YOUR TAGS WILL COME IN WITHOUT A LEADER.
