I have been trying to create a stair case but i can not get the top of the stairs to line up correctly. When i do gent one platform to line up the riser sticks up above it. If you know how to remove this riser plaes let me know
Check the stair's type properties. There is a setting for "End with riser" which can be on or off.
Stairs > Stairs by sketch > Type properties > Risers > Begin with riser or End with riser
Not available if you use Stairs > Stair by component
