Relative coordinates on revit
6 REPLIES 6
2202 Views, 6 Replies
I asked this someqhere else but I thought I'd give it a try here so....
I'm a veteran AutoCAD user. I'm currently learning REVIT from a video tutorial I bought, but there's one small thing that's driving me crazy. How do relative coordinates work on REVIT? When drawing a line on AutoCAD you’d start the command, then click on the first and then type let’s say @5,9 That’d make the second point of that line to be located 5 units to the right on the x-axis and 9 units up on the y-axis from the starting point. How can I accomplish the same basic operation on REVIT? Same thing goes for moving an object. How can I move a column 3 meters to the right and 5 meters up without moving it twice, once in each direction, or calculating the distance and angle ?Please help a newbie!
6 REPLIES 6
You need to start thinking Revit is completely different product from AutoCAD. Many of your AutoCAD knowledge will not help.
Just like they said in Avatar to Jake Sully: It is hard to fill a cup that is already full. Think like you never learn CAD before.
Translation:
The function you are looking for is ABSENT in Revit.
It remains a mystery to me why such a basic, standard feature in a cad/graphics program has been left out.
bt
Finally! Somebody gave me a straight answer!
People at Autodesk, please consider adding this feature in future releases. It'd be quite a time saver!
joeldf
Honestly, once you actually use the program, after a while you learn all the other ways of at least getting the same results. Not all of it is always better or faster, but you figure it out. Some things are better, and some not. But in the end, it's the coordination that becomes easier. I've been using Revit now for about 3 years, and have used Acad and the various architectural add-ons (DCA, Auto-Architect, SoftDesk, Arch-T, and ACA even now) for over 20 years now. Some things are still frustrating to deal with ("I want to do this - why can't it just do it"?). For one thing, the inability to simply explode a component detail totally baffles me beyond belief. But, there are many other things you can do in Revit that, after figuring them out, make up for those frustrations. You have to actually start using Revit, and you end up getting the result you want in a different way. I found that I don't miss the specific relative input method you mention as a way of doing things. In fact, I rarely used it to begin with.
Joel
blinov.ua
I agree with you!
It is strange that I can indicate the length of the wall or line, but I can’t indicate its direction!
RobDraw
in reply to: blinov.ua
This thread died many years ago.
Rob
