Reflected Ceiling Plan Greyed out and no Fine detail
3 REPLIES 3
mhamson
3695 Views, 3 Replies
   I have one of the floors in our building doing something wacky.
   The 5th floor reflected ceiling plan looks fine so I create detail plans for the suites at a different scale. this new suite blowup has what looks to be the same suite but everything is greyed out and when i switch from coarse detail to fine detail it doesn't do a thing.
   The orignal full reflected ceiling plan looks fine. The line are black. The detail swithces back and forth...
   I can;t figure out what the problem could be. I used the same process on other floor and everyting is OK.
   The View Ranges are the same and everthing else in the properties seem the same too.
   Anyone else come across this?
Mike
3 REPLIES 3
LisaDrago
in reply to: mhamson
Not specifically - what is the discipline set to?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
mhamson
That s wasn't it...but it did make me look at the bootom of the properties dialgue box and notice that the Phase was set to "Phase 3". We don't even have phases in this project. Ooops! Wonder how that got changed.
Problem solved.
Thanks for the help.
MIke
LisaDrago
Glad to be of assistance... kind of...
LD
