Revit Architecture
Revit Architecture
Distinguished Contributor
diesellam
Message 1 of 6 (437 Views)
Ready to transfer CAD to Revit (set it up right from the beginning)
437 Views, 5 Replies
10-24-2012 03:45 PM
OK, I'm ready to convert the CAD file into Revit.  Please see attached file.
I want to make sure I start everything right before I jump into it.
The project location:
This site is an empty land right now, doesn't have any streets yet.  But eventually it will.
So what should I enter for the project address since there's none right now.
File setup:
There are 2 types of building: Type A, Type B.
I'm thinking to have 1 file that has the terrain (green) and building C.
Type A, 1 file; Type B, 1 file.
I'll link both Type A, Type B into the file that has the terrain and building C.  Is this the right approach?
Also, since the site is angled, I think after the linked files should be angled, not the original building files, right?
Then the question is: do I just rotate the linked files after I linked them?
The project origin:
Does it make sense to setup up at B306?
Google Earth:
I want to set it up right from the beginning so that I can export the whole model accurately into Google Earth?  What's the best way to do it?
Bob_Zurunkle
Message 2 of 6 (414 Views)
Re: Ready to transfer CAD to Revit (set it up right from the beginning)
10-25-2012 09:31 AM in reply to: diesellam
Consider linking your CAD file as an underlay in Revit. Also, if your CAD file has an origin, there is an option in the link box to go origin-to-origin.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Product Support
alan.quinn
Message 3 of 6 (377 Views)
10-30-2012 09:40 AM in reply to: diesellam
See my comment below:
Leave it blank until you have an address.
File setup:
Depending on the size of your building you may want to create separate files for each building and another for the site and link them all together into a separate Master File. This is where you will do all your annotation.
I'm assuming you mean the site is sloped....correct. However, your buildings will need to be build to suit the site. See this link for detailied information on Shared Coordinates: https://dl.dropbox.com/u/11938886/Shared-Coordinates.pdf
The project origin:
I don not know what B306 is. See DropBox Shared Corrdinates PDF. Its a big file with lots of information, but it will answer all your Shared Coordinates questions.
Google Earth:
Download and install Globe Link add-in from the Subscription Center. See this link for more detail on what version of Google to use, see last line. http://wikihelp.autodesk.com/Revit/enu/2013/Help/00005-More_Inf0/0001-Subscrip1/0015-Globe_Li15/0016...
Hope this helps and thanks for posting.
Alan Quinn
Support Specialist
Product Support
diesellam
Message 4 of 6 (370 Views)
10-30-2012 09:58 AM in reply to: alan.quinn
Thanks for the response.
I was looking into the share coordinate info.  I think your answer reminds me that I'm heading the right direction.
When I said "roate" the building after I linked them, I meant the orientation of each house.  Like the true north vs project north.  I was saying when I make the changes in each file of the house A, B, the orientation still remains true north: walls are parallel to the x, y axis.  Then, after I link these files into the master file, I'll rotate the house per the project north.  Is this the right way to do it?
Product Support
alan.quinn
Message 5 of 6 (328 Views)
11-01-2012 11:18 AM in reply to: diesellam
Yes, you can do that, or you can duplicate a floor plan in the actual house file and set that to True North. In any event the PDF will provide more details and if you do a search on YouTube you will find lots of videos that both explain and demonstrate what you want/need to do.
Thanks again,
Alan Quinn
Support Specialist
Product Support
diesellam
Message 6 of 6 (325 Views)
11-01-2012 11:20 AM in reply to: alan.quinn
Cool.  Thanks once again for all of the info you've provided.
