raytrace problem
4 REPLIES 4
nsgarrod
674 Views, 4 Replies
raytrace problem
I am trying to render a house that I designed. My problem is that Revit does not give me the option of raytracing. I have gone through to make sure my settings are correct, but still nothing. I also have loaded up tutorial projects, and still I do not get the option of raytracing. I am out of ideas, can anyone help?
4 REPLIES 4
in reply to: nsgarrod
Are you in a 3D view? Not on the sheet? Nor on the browser? The view itself
has to be active...
wrote in message news:5145495@discussion.autodesk.com...
nsgarrod
yeah, I'm in a 3D view, but I still don't get the option of raytracing.
did you go to a floor plan view, then View>Camera, place a camera and aim
it?
Then you go to Render>Raytrace
...of course there's a few more steps in setting your shot up...clouds, sun,
size, etc
wrote in message news:5150504@discussion.autodesk.com...
JeffreyMcGrew
If you filepaths aren't set correctly to the Accurender rendering resource, the Rendering options will be greyed out. Are your paths correct under Settings -> Options -> Rendering? What's the first path listed at the top?
