Ramp Max Slope
4 REPLIES 4
GHASEM_ARIYANI
9034 Views, 4 Replies
Ramp Max Slope
hi
Can you Explain About Field Ramp Max Slope (1 / x)?
Performance  This Amount How is?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
in reply to: GHASEM_ARIYANI
1/x where X = the horizontal distance travelled to go up '1' unit in height.
ie - if metres a value of "12.0000" as shown a 12m long ramp will rise 1m - (shortened to 1m in 12m - or 1/12).
In Revit this sets the maximum (Steepest) gradient a ramp will use to get to the required level.
GHASEM_ARIYANI
Thanks for you
travis.architect
Do you mean 12.000 = 12m?
longt61
in reply to: travis.architect
I believe that not what the answer meant. the mentioned "unit" is what ever the current length unit you are using in Revit , be it meter, foot, inch etc.. etc..
The ratio 1/x means that a ramp with x unit long will be 1 unit high ( x meter long - 1 meter high, x foot long - 1 foot high ...) The number 12.000 only means that you can specify the ratio up to 3 number after the floating point.
