Ramp Annotations
2 REPLIES 2
cemcap
782 Views, 2 Replies
Ramp Annotations
Hello again.
I want to share a problem in Revit Architecture 2011. When you create a ramp in a specific level, you cannot put annotation on this ramp on the level you have created it. Bu when you go to the upper level, you can put annotation on this level clearly. After doing up such annotations, you can copy these annotations to the level below (to the base level yo have created the ramp) the annotations go there clearly and they amazingly show the levels of the ramps. Is there a solution for this problem?
Thanks and regards,
2 REPLIES 2
ryan.duell
in reply to: cemcap
Regarding annotations, are you referring to the “Up” and “Down” annotations that are part of the ramp element?  Or are you adding text directly over the ramp?
You should be able to show the labels on both levels by default, if this is what you were referring to.  If this is not the case please let me know if you have a more specific example:
Thank you,
Video Example: http://screencast.com/t/cX0LibfjJ9T
Thank you,
Ryan Duell
cemcap
in reply to: ryan.duell
Dear Ryan,
Thanks for the reply. But my question is a little bit different, so i have uploaded a video to
http://www.screencast.com/t/ZDG0lpfD
for you to view.
Thanks and regards
Cem.
