I just tried the move levels trick on my own model, BTW, as an experiment
and it worked fine. I got ONE warning about a wall and a floor that couldn't
stay joined and I just clicked "Unjoin elements", then rejoined them and all
was well. Why Revit couldn't keep them joined I dunno, but it wasn't a big
deal.
"Matt Dillon" wrote in message
news:6326545@discussion.autodesk.com...
Doing a simple Move on the entire model is probably not advised. You might
try grabbing all of the levels and moving them up 2'-6" and see what
happens. Model geometry which is tied to the levels will move with them. I'd
save the file first and check it VERY carefully aftwerwards.
If that fails or becomse problematic, try using the Relocate Project tool -
Tools->Project Position->Relocate Project. Do it in an elevation view - move
the entire project up 2'-6". Then use the regular Move tool to move the topo
back down 2'-6". The level tags will still show the original elevations,
however, because you've moved the entire project, including its elevation
base. You can edit the level tag type properties however and set the
Elevation Base property to "Shared".
wrote in message
news:6326493@discussion.autodesk.com...
I am trying to raise my entire structure up 2'-6" in
relation to the topo site. Can anyone help me do
this in Revit 2008?
