Revit Architecture
Revit Architecture
Valued Contributor
1 Kudo
Post 1 of 3
Railing terminations don't show in plan.
270 Views, 2 Replies
11-08-2013 12:51 PM
I've created custom railing terminations and applied them to a handrail. They appear in every view extept plan. Railing extensions show fine. Railing Terminations don't. I am including screenshots & the families. Visibility is on for all views and all detail levels. Linetype is set to solid in Object Styles and VG. View Range is fine. Cut plane is way above the railing and bottom is unlimited.
The weird thing is that the extenstions appear in blue when the railing is selected. But they dissappear otherwise.
If anyone has any light to shed on this problem I'd very much appreciate it.
Thanks !
JF
Product Support
10 Kudos
Post 2 of 3
Re: Railing terminations don't show in plan.
11-11-2013 08:29 PM in reply to: jfmonod
Thank you for your post.  In this case I do apologize but at this time we do have reports of this known issue in the current software configuration.  I would suggest utilizing our development feedback link below that will enable our end users to contact and solicit feedback on these issues that they are working on to address in a future update/release.  This can help gain further momentum and priority in future fixes.
Development Feedback Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Again I do apologize but at this time this is a known issue within the software at this time.
Michael Bussiere II
Support Specialist
Product Support
New Member
0 Kudos
Post 3 of 3
12-29-2014 02:44 PM in reply to: MichaelBussiere2
Has there been any resolution to this? Created custom railing terminations and also can't get them to show in plan. Revit 2015 Release 3.
