Unfortunately, if there are other ramps in the project - they will also be
turned off. So this is not the best solution in many cases, as ADA ramps
abound.
"glynnis [IMAGINiT]" wrote in message
news:40852a57$1_2@newsprd01...
> I'd just make a ramp, to which the railing can be attached and then turn
the
> ramp visibility off. Make sure that when you move the railing you are
> actually moving the ramp to which it is attached; otherwise the railing
will
> become detached.
> Sincerely,
> glynnis patterson, Architect
> RAND IMAGINiT
> www.rand.com/imaginit
